Bug with component lock/unlock
vpapanik
vpapanik
I would like to report a small bug.
When I unlock a previously locked component, its labels are unlocked too. However, when I click on a label to move it, it re-locks again !
The only way to make it work is to deliberately select the Modify/move tool just BEFORE I click the label in order to move it, just AFTER I unlock the component.
jorge_garcia
Hello @vpapanik ,
I hope you're doing well. It's not a bug, commands stay active until you cancel them or switch to a different command(which is what you've been doing). After you unlock the component go ahead and press the ESC key a couple of times to cancel the command.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
