[BUG] PCB trace width is constantly reset to 0.1524, makes Fusion unusable
marcocipriani01
marcocipriani01
I would like to report that the "Trace Width" routing parameter gets constantly reset to the minimum (0.1524mm) every time I try to route a new PCB trace. This means I have to set the width I want for every new trace.
The issue is present regardless of which PCB design I'm working on, across restarts and even after cleaning Fusion 360's cache. It was not present before the latest update (the current version is 2.0.13377).
Please fix it as soon as possible because it makes PCB design incredibly tedious.
jorge_garcia
Hi @marcocipriani01 ,
I hope you're doing well. Check your preferences see if Auto set route width and drill is unchecked. If it's unchecked than it should use whatever the last setting you used was. If it's checked then that would explain the behavior you are seeing.
Best Regards,
Jorge Garcia
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
marcocipriani01
Thank you very much, that solved the issue. I have no idea why that option got checked. I didn't touch anything in the settings recently.
