Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Bug: in some cases, moving a selection causes nets to snap to the nearest angle (New Selection Behaviour)
3 REPLIES 3
motla.design
139 Views, 3 Replies
First I want to thank all the Fusion Electronics team staff who worked on the "New Selection Behaviour" feature. I tested it since the release and it is just great, and improves usability of Fusion Electronics a lot! 👏👏  Usually I complain but this time I'm very happy.
I just found a little unintended behavior, it is when moving a selection. I made a minimal example. Just watch the screencast below, you can reproduce it easily (the net should move along but not snap).
Romain
Tags (1)
Labels (1)
  • bug
3 REPLIES 3
Hello @motla.design,
Thank you for bringing this up, I've reported the issue.
We are super happy that you are enjoying the new selection mechanism. Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Hi @motla.design,
I hope you're doing well. I spoke to our devs, they will look into this. For now you can circumvent the issue by making a smaller selection.
Best Regards,
Jorge Garcia
panpan_fan
in reply to: motla.design
Hi @motla.design
I hope you are doing well!
Thank for reporting this issue to us!
Except for @jorge_garcia2 's suggestion, I want to share another workaround to you.
For the new selection, group selection from left to right and right to left have different selection result.
  • Left to Right - Must include all of the objects to make the selection
  • Right to Left - Only including a partial of the object can make the selection
For your issue in the video, you do the group selection from left to right. So the marked net in the following screenshot is not selected. It causes the bug .
As a workaround, you can do the group selection from right to left. Then you can do the Move. It will show the expected result.
We will keep you updated when we fix the issue. Sorry again for all inconvenience.
Panpan Fan
