Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Bug in AC simulation, using the Eagle opamp1.sch example
2 REPLIES 2
holger.vogt
126 Views, 2 Replies
The simulation fails, after sucessfully reading opamp1.sch from the Eagle analog simulation examples.
Reason is a wrong parameter in the ngspice netlist, caused by a wrong parameter selected in the Fusion360 simulation window. The AC Sweep allows as Art the parameters Lin or Dez from the dropdown menu. Dez is wrong, it has to be Dec. The simulation fails. In Eagle the simulation is o.k.
Excerpt from simulation windowExcerpt from simulation window
2 REPLIES 2
panpan_fan
in reply to: holger.vogt
Hi @holger.vogt
I hope you are doing well!
I can reproduce issue in Non-English Fusion 360 and I will report it to the develop team.
I will keep you updated when we fix this issue.
The workaround is that you can use the English language Fusion.
Sorry for inconveniences.
Panpan Fan
panpan_fan
Hi @holger.vogt
Today we release Fusion 360 V2.0.14567 and this issue should be fixed now.
Please update Fusion 360 and have a try again, thanks!
Panpan Fan
