Bug: Corrupt file when pushing to fusion
a.skala
a.skala
I often face issue with Fusion and Eagle. When I try to push a board changes from Eagle to Fusion, it some times fail. Push in eagle ends with successful message, but when I try to open board in Fusion, I get this error:
I always have to unlink board in Eagle and push it under a new name, remove old from my assembly and add a new to it.
Opposite direction works always.
Fusion360: 2.0.10806
Eagle: 9.6.2
Accepted solutions (3)
a.skala
Another kind of message box when file is corrupt.
a.skala
Now I also get pdf generated in folder where I push with name of Design and  `_errorReport.pdf` with content:
Only way to overcome is to unlink design and link it in new file in Eagle.
panpan_fan
Hi @a.skala
I hope you are doing well!
Sorry to hear that you can't do Fusion Sync successfully.
Would you mind sending me your brd file to have a look? We think the translator error may be related to your file.
I will send my email address to you as a private message.
Panpan Fan
JuergenGe
I have the same issue with several files.
Is there a general solution to this?
panpan_fan
Hi @JuergenGe
Would you mind sending me your files to check?
Panpan Fan
a.skala
Hello @panpan_fan, email sended.
