Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Bug caused crash, F/B Annotation broken, lost version...
2 REPLIES 2
scott.nortman
188 Views, 2 Replies
While working on a PCB, I clicked on a trace segment to delete, Fusion would not respond, and after a moment popped up a warning window that F/B annotation was severed; was unable to close the window, please see the video:
https://drive.google.com/open?id=1HaDrEJWB5P9CeuRePn3mPNAXovjtGIf-
I had to kill the Fusion process to move on; this broke the F/B annotation and I had to revert to earlier versions.
Please advise...
2 REPLIES 2
I lost F/B today as well. ERC from schematics does not help.I have missing parts on board.
Hi @christopher2KLSVU,
In that situation the easiest thing to do is to remove the parts from the schematic. The goal is to get the schematic and board the same. Once they are the same and consistency has been restored (by running ERC once the consistency errors have been fixed) then you can continue working. This is very important, if you keep working while consistency is broken you are just burying yourself deeper into the hole.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
