Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Broken 3D board link new 3D board version in mechanical design
2 REPLIES 2
ambios
128 Views, 2 Replies
Somehow my 3D PCB name updated to xxx - Rev3.1 v4 from xxx - Rev3 and now my link to the board inside the mechanical design is broken. I know that I can unlink the design and then re-link it, but I've spent a lot of time repositioning it. I'd like not to have to recreate this. Is there a way to simply link to this new version (which is fundamentally identical - few trace changes and text) to the previous version? In the mechanical design, I can open "choose version" but the connection to the newly named Rev3.1 is not shown.
Thoughts?
Patrick
2 REPLIES 2
jorge_garcia2
in reply to: ambios
Hi @ambios ,
I hope this message finds you well. It sounds like you saved the model as a separate file. In that situation you would have to to break the link and re-insert it as you have mentioned. Keep in mind that the MOVE command in Fusion has a point to point option which can make it really easy to locate the board onto your assembly.
I wish I had better news, let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
ambios
in reply to: jorge_garcia2
Hi Jorge,
Thanks for the quick response, you're the best!
I was afraid of this. You can see from my screen shot that the board is round. Although I can use the point to point option to position one mounting hole in the center of the mount, it is hard to align the board rotationally. I can get pretty close by eye. and I'll likely just do that.
Thanks again,
Patrick
