Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Bring back Polygon pour Type: cutout
2 REPLIES 2
HF_Claus
104 Views, 2 Replies
I just created a new PCB in Fusion 360 with a 4 Layer PCB and wanted to create a cutout area on the inner layers underneath a DC / DC converter. In eagle I could select Polygon Pour "cutout"
I don't know when the Update happened in Fusion that broke this behaviour was done, but this Dropdown menu is missing, instead I only have the possibility to select "hatched" through a checkbox.
I tried to use the commandline to change the polygon pour type with "change pour cutout" but nothing happens when selecting a polygon.
I realy need this functionality so please bring it back or tell me some workaround if it exists.
I dont want to export the project, do the changes in EAGLE and then reimport it, so please give me a solution that is practicable
Best wishes
Markus
Labels (1)
2 REPLIES 2
silvio3105
in reply to: HF_Claus
Maybe this helps?
HF_Claus
Thank you, just overlooked this setting a hundred times!
