Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Blank 3D-model - Circular Dependencies
4 REPLIES 4
erik.hole
136 Views, 4 Replies
When I try to synch my PCB to 3D-viewer I get an error message and the model goes blank. Somehow Fusion is making it's own circulart dependency of the 3D-models.
Also. When are soldermask going to stop overlaying pads?
Best regards,
Erik Hole
4 REPLIES 4
jorge_garcia2
in reply to: erik.hole
Hi @erik.hole ,
I hope you're doing well. The soldermask issue will be resolved shortly so stay tuned for that. Now I don't know what could be going on without seeing the files. I'm going to tag the developers onto this thread, but if you have any files you can share that will help.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
erik.hole
in reply to: jorge_garcia2
Is there a way I can send the files in private?
yiqiu.han
Hi, @erik.hole
We have delivered a fix for circular dependency issue in May release of Fusion 360(2.0.10244+), you could break link for current 3D PCB and then generate a new one to abandon corruption 3D PCB. If you have any other workflow that would generate this problem again in the new build, please let us know.
For the stop layer cut soldermask area, it has been implemented in May release also, see my last post on https://forums.autodesk.com/t5/fusion-360-electronics/the-new-layer-set-dialog-is-restricting-workfl...
Yiqiu
erik.hole
in reply to: yiqiu.han
Ok, glad to hear that some of the most annoying bugs are starting to be cleared up, as there are quite a few of them :')
I used the break link functionality to fix it, and got back on track.
