will flip/mirror command will be updated?
For now, mirror only changes top to bottom and vice versa.
So, my idea is to extend move command with flip -> Flip selected objects on same layer over X or Y axis.
Also, UX is really bad with move and mirror commands. I'm using Fusion for over a year(for electornics) and I'm still not sure how it works.
In this case, I select objects, press M(move command) and click onto mirror icon. It does nothing. I have to first open move command, select mirror command and then click on every object I want to mirror. And after I click on it, it starts to move. Also, why mirror command has unmirrored and mirrored icon?
First, flip should be tool that flips objects onto bottom/top layer. Mirror should be tool that mirrors selected objects onto same layer over selected axis(at 0,0 point).
Second, UX should be better. Separate move, flip and mirror commands. For flip and move it should be this workflow - select objects, launch command, select commands options(in GUI, not with text) and click ok.
In case of mirror(not current mirror) options would be X or Y axis.
