Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Best way to name pin from terminal block inside a schematic (not from library)
0 REPLIES 0
Message 1 of 1
AutomaticRock
139 Views, 0 Replies
Hi Everybody,
What is the best way to add pin name/functions to terminal blocks or connector inside a schematic (not from library)?
I have symbol for 1 terminal point. I use this symbol for 2way and 3way terminal blocks and connector.
Depending on the use the pin can various functions, and therefor various names. For example a 3 way connector can have pin1 for Input, pin2 for GND, and pin3 for Output. So this text I would like to have in the schematic.
First I tried this with attributes (>TEXT), but it seems an attribute is set for a device and not per gate.
So now I have made it with simple a simple text, like this:
So the 3way connector device in the library looks like this:
But when I place the part the text is there, but it's locked. I cannot edit the text. I cannot even move or delete the text...
So this doesn't work either.
The only thing I can think of is add the text in the schematic. But that way it's not part of the device (gate).
What I was hoping for is:
- add an attribute per gate, not per device
- or add editable and movable text to a symbol
Since this seems to be impossible, what is the best way to handle this?
Best regards,
Benno
Labels (3)
0 REPLIES 0
