Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Bad UX with dimension tool
2 REPLIES 2
silvio3105
67 Views, 2 Replies
UX with dimension tool is really bad. I got feel like its some tool for generating silkscreen stuff.
Why even we can control line width and that stuff for dimension???
Also, it's hard to delete it. Tool thinks its smart so it "knows" what I want to measure - When I select one point(eg. silkscreen line) it thinks that I want to measure between two symetrical lines. I don't like that.
https://youtu.be/yaIkGZRnB1o
2 REPLIES 2
jorge_garcia2
in reply to: silvio3105
Hi @silvio3105 ,
I'm reporting this now. It will be considered low prio (given everything else we have going on) because it technically works but I agree it needs an overhaul. The magical spot for deletion is generally near the center of the displayed number. Sometimes I just make a big selection window to make sure I catch it.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
silvio3105
in reply to: jorge_garcia2
Nice. Make it like in Fusion. Without that "smart" component where F3E selects second point(after user selects first point).
