Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Assembly Variant on 3D-PCB
1 REPLY 1
iPack90
110 Views, 1 Reply
Hello there,
i have different assembly variants of an pcb and a couple of components shall not be populated.
As far as i understand, i can only select the variant in the shematic.
Now, if i push my board to 3D PCB, all packages show up, regardless of the pcb variant selected.
For documentation purposes i would like to show the 3D PCB exactly as defined in the specific variant. So unpolupated parts are actually unpopulated.
Is there a way to select/show a pcb variant in the 3D PCB window which i can not find?
I know i can hide each part manually, but ideally i would just like to switch between each variant in the 3D PCB window.
E.g. in the "CONFIGURE 3D PCB" Window, a button to select a variant and hide/show unpopulated parts.
Thanks and best regards
1 REPLY 1
yqliu
in reply to: iPack90
@iPack90 , Assembly Variant is not supported in 3D PCB yet.
