Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Assembly variant in Fusion electronic.
4 REPLIES 4
duc.chunguyen
205 Views, 4 Replies
Hello Team,
I had making assembly variant and remove some part, but it's still available on pick and place file?
Anyone have suggestion for clear this issue?
Many thanks.
4 REPLIES 4
gtoner2506
in reply to: duc.chunguyen
On simple variant just use an editor to take out the required components. This must be redone every time the PNP files are regenerated. This issue must be addressed as it renders the variant capability useful only for making a BOM from the OUTPUTS menu.
Hi Everyone,
Thank you for the feedback, we really appreciate it.
@HelenChen-ElectronicsQA This is a worthwhile enhancement request it would be good to make a ticket for it.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Hi @duc.chunguyen@jorge_garcia2 ,
Thank you very much for reporting this issue and so sorry for any inconvenient.
I will log an improvement about this.
By the way, I tried on EAGLE 9.6.2, and noticed even if we choose the variant which has hidden the part, in the CAM processor, there is a tooltip to remind the CAM processor will output all objects to PnP, regardless of current variant setting.
So the easiest workaround currently looks like to remove the parts from the generated PnP files manually as @gtoner2506 suggested.
Hope it helps a little.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
@HelenChen-ElectronicsQA Thank you a lot, I had doing hand by hand for my design before. But when we're going to Manufacturing the design this is take a lot of time and raising assembly failure rate.
Looking a updated ASAP.
