Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Arc for polygon
4 REPLIES 4
silvio3105
111 Views, 4 Replies
Arc for polygon
I'm trying to create tCream with polygons. It's for SMD standoff footprint. Recommended stencile cutout is below.
I cannot create it because Miter command does not support both radius types. Image is below.
4 REPLIES 4
jorge_garcia2
in reply to: silvio3105
Hi @silvio3105,
I hope you're doing well. You could achieve the desired tStop opening using the polygon command with semi-circular bends. You have to calculate the 4 vertices of one of the slices and then make 3 rotated copies. See the attached image.
Let me know if there's anything else I can do for you.
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
silvio3105
in reply to: jorge_garcia2
Thanks for image, but I need to create 1/4 of circle(see image from standoff datasheet in first post).
And I need tCream for stencile. So I've placed PTH but it does not generate stencile for it.
That could be another feature request - tCream for PTH.
Also, I can create DXF in AutoCAD and import it in Fusion. Reason why I opened this topic is to point that some features are missing - like in this case "negative" radius.
jorge_garcia2
Hi @silvio3105,
The circle image is just to give an idea of how you can make curved polygons since that would help you get the shape. I agree that we are missing drawing features.
Plated through holes don't generally get a stencil because the drill wicks the solder paste down into a hole.
Best Regards,
Jorge Garcia
silvio3105
I hope you wrote that info about drawning features 😛
