Appearance of generated 3D packages
silvio3105
silvio3105
appearance of generated 3D packages are polished. Does not look good.
jorge_garcia
Hi @silvio3105,
It looks like you are doing a rendering. If you don't like the appearance of the  surface mount components you can always go into the library and change the material properties so that it's not a mirror finish.
It's possible the render environment allows you to modify this as well but I'm not familiar enough with the rendering environment to know for sure.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
silvio3105
Yes, that is a render. In 3D workspace it does not look like this.
I did not know how pads will look like since there's no PCB in 3D view of footprint in library and I was lazy but I did not expect to have mirror finish.
I hope AD will change default material for generated 3D models.
Not big deal for me, just to be clear.
