Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Analog Source Setup Problem
6 REPLIES 6
jonas.wilhelm1
347 Views, 6 Replies
Im new to Autodesk Electronics and im trying to build a bridge rectifier as a first project.
I chose to simulate the circuit with the ngspice library and i am running into a problem when setting up a sinusoidal function in the analog source setup of the independent voltage source.
Every time i select the sin function and enter an amplitude,frequency and hit apply, the settings just dont get applied to the circuit. I can enter a DC or AC Voltage and it will apply, but when i choose a transient function and reopen the source setup, it will just show that no transient function has been chosen.
Am i entering something wrong in the parameters or is it a bug?
Thanks for any help.
Labels (1)
6 REPLIES 6
Heres a screenshot of the source setup that i mean. When hitting apply - in german "Wert festlegen" - the transient function is not added to the source.
Hello @jonas.wilhelm1 ,
Could you temporarily try switching to English Fusion? I wonder if there's any issue with the button because of the translation. Just as a test.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Thank you! That did it.
There seems to be some error in the german version. I will be contacting the fusion support to get it fixed!
Best regards,
Jonas
janisET889
in reply to: jonas.wilhelm1
Thanks for asking that and getting the answer published. I would not have figured that out in a million years. Vielen, vielen Dank! 😅
bayous
It's also the case for the french version.  Switching to english version did it
panpan_fan
Hi @jonas.wilhelm1 @bayous @janisET889 ,
I hope you are doing well!
Today we release Fusion 360 V2.0.16753 and this issue should be fixed now.
Please update Fusion 360 and have a try.
Panpan Fan
