Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Analog source cannot be set
5 REPLIES 5
CI7090
201 Views, 5 Replies
I tried to set the analog source for "VOLTAGE" in "ngspice-simulation", but the setting is not saved.
Sorry for the Japanese account.
If you know the problem, please let me know.
5 REPLIES 5
panpan_fan
in reply to: CI7090
Hi @CI7090
I hope you are doing well!
Sorry that it is a known issue that the  Transient function of Analog Source Setup can't be set successfully in non-English languages.
Would you mind change language to English again to see if it can work well for you?
I will keep you updated when we release the fixing for this issue.
Panpan Fan
CI7090
in reply to: CI7090
@panpan_fan
Thank you for your reply.
I see that this was a bug that has already been reported.
I changed the language setting and the problem is solved. Thank you very much.
panpan_fan
in reply to: CI7090
Hi @CI7090
Today we release Fusion 360 V2.0.16753 and this issue should be fixed now.
Please update Fusion 360 and have a try.
Panpan Fan
CI7090
in reply to: CI7090
@panpan.fan
I have confirmed that it works.
panpan_fan
in reply to: CI7090
Hi @CI7090
Good to know it works for you!
Panpan Fan
