ALL Components locked in design
kevin2MSFQ
kevin2MSFQ
In my PCB design, ALL of my components show ( and behave ) as locked, but none of the componnts have the 'locked' property set.  See the screenshot below:
Is there some 'global lock' function that I have accidentally activated?
Much thanks for any help,
Kevin
matt.berggren
Quick fix would be to go to the “selection filter” panel on the right (typically) and select only components.  Then use Ctl+A in the canvas to select the parts.  This will only select parts because you filtered out all other objects.  From the inspector panel, uncheck the option for Lock and this will unlock all parts.  VIP: go back to the selection filter panel and click Reset to enable object selection again.
Hope this helps!
matt - Autodesk
kevin2MSFQ
This did not work.
Please take a look at the screen shot in the initial post and observe that the highlighted component displays and behaves as locked, but the property panel shows locked is not selected.
kevin2MSFQ
Tom got me all squared away....
I had accidentally locked the tOrigins layer and this in turn locked all the components on the layer
Thank you for the help!
