Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Airwire Check Showing False Positives
2 REPLIES 2
wleismer
287 Views, 2 Replies
I have some Airwire check results that are reporting a connection is not made when a trace is routed to the pad.  I thought that maybe there was a wire stub that was very small and hidden by the SMD pad causing the error. So, I selected all traces within the pad and deleted them before re-routing a trace into the center of the pad.  After re-running the airwire check, Fusion360 still flags it as "not connected".
One photo below shoes the false positive Airwire being flagged by Fusion 360.  The second photo shows me routing a trace directly to the pad, ensuring that I am getting "center lock".  After rechecking for Airwires, the false positive still shows up.
Am I missing something else that I should be checking here?  This has happened before, and I just accepted the Airwire since the connection is obviously made, but now that it is happening again, I am nervous about the accuracy of DRC.
Tags (2)
Labels (1)
2 REPLIES 2
lodderj
in reply to: wleismer
The older eagles did this as well.
When you disable all layers except unrouted you will see a tiny tiny slimmer of unrouted.
When you click on it with the route tool it usually fixes it.
wleismer
Ah, nevermind, I tried again today by closing out the DRC error window after I fixed a supposed airwire, then re-ran the DRC check again and the issue was gone.
