Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Airwire between two connected pads
5 REPLIES 5
silvio3105
135 Views, 5 Replies
There's a bug. Two pads are connected with polygon, but airwire is still present. Polygon refill does not help.
Here's image. Thanks.
5 REPLIES 5
silvio3105
in reply to: silvio3105
This solved problem.
silvio3105
Bump!
silvio3105
Little bump
jorge_garcia2
Hi @silvio3105,
I hope you're doing well. Are you still seeing this? There were some improvements in the polygon implementation.
Let me know if you still see this behavior.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
silvio3105
in reply to: jorge_garcia2
Nothing for now. I did not created any PCB after this PCB where I found this bug.
