Announcements
airwire across resistor
gixxerrider73
gixxerrider73
I have a fairly simple PCB.  I used autoroute and it creates a trace across two of my resistors affectively shorting them out.  If I do manual routing, an airwire is still shown across the resistor and I can't figure out why.  is this common, i feel like i can just ignore it.
The resistors in question are circled in yellow.
jorge_garcia
Hi @gixxerrider73,
I hope you're doing well. This is almost assuredly and issue in the schematic. Take a look at your schematic, more than likely you have some errant net segments shorting the resistors. Whatever the issue is, it's likely on the schematic.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
