Announcements
After startup and libraries update - can not close Library Manager window
christopher2KLSVU
christopher2KLSVU
Windows system Close function does not help same with main Fusion window. These are peanuts but..never happened before last update.
I have killed the main process, and after new startup is fine.
HelenChen-ElectronicsQA
Hi @christopher2KLSVU ,
Sorry to hear that you're having trouble.
Fusion 360 had an update yesterday and the latest version is 2.0.9305.
Could you please upgrade to the latest version and see whether you still have the issue - "cannot close library manager window"? Maybe you could restart the machine to have a try again.
Hope it works well for you now.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
christopher2KLSVU
This was just once after previous update. Not seen again.
Thank you very much for your updates, @christopher2KLSVU .
It's so glad to hear that it works for you now.
Please feel free to let us know if you need our further assistant.
Helen
Helen Chen
christopher2KLSVU
With fresh installed fusion I see the same problem again. All tabs closed, opening the project from panel data, then I become blue bar with message that libraries have to be updated, done, but  I can not close Library manager window. Thus I must kill f360.
Sorry that you are having trouble now.
I tried both on Windows 10 and Mac 10.15.7, I cannot reproduce this crash unfortunately.
Could you please take a screen shot of the blue message you see in the editor? Actually I cannot see the blue message you mentioned in my design... (not sure whether I missed anything...)
Could you please try to add part in the schematic file > select the part to add whose library need to be updated > In the pop up dialog to remind upgrade the library, choose to upgrade the library > place the updated part in the editor?
I'd want to see whether this workflow works for you or not?
Thank you very much for your help.
Helen
Helen Chen
christopher2KLSVU
I have not had windows blue screen. It was light blue bar as usually what force me to update managed libraries. The bar Actually it is every time after start up of fusion. Nothing special just library manager window can not be closed.
