Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
After modifying footprint signal routing gets deleted
2 REPLIES 2
anuradha.bodke
143 Views, 2 Replies
Hello Team,
I am using Fusion 360 Electronic for pcb design
if I completed signal routing and after that some component's footprint was modified
after replacing that part signal routing get deleted and this was not happened earlier version
Please give solution on that
Thanks In Advance
Anuradha
2 REPLIES 2
Hello @anuradha.bodke ,
Sorry to hear that you're having trouble.
I am able to reproduce the issue you reported, thank you very much for reporting to us.
As a workaround before this issue is fixed, please use the way to Update all libraries used in this design instead but not use Replace command.
It should help.
Sorry for any inconvenience.
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
Hi @anuradha.bodke ,
Hope all is well.
We have fixed this issue in latest Fusion release with version 2.0.13615.
Could you please upgrade to latest version to have a try?
Hope it helps.
Best regards,
Helen
Helen Chen
