Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Adding a buss is not working quite right for me.
1 REPLY 1
acsann
78 Views, 1 Reply
You can see that there are net names on the connector at the bottom of the schematic but there are no net names up above on the MCU board. How do I add net names on the top end of the buss?
1 REPLY 1
jesper8W75R
in reply to: acsann
You can right click on the bus, choose "Breakout bus", then single or all nets, as you need. They will be automatically labelled.
Or, you could simply add LABEL to each net.
As you would normally do when NOT using a bus.
Right-click on the net, choose "Label".
