Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Add info other than NAME and VALUE in symbol
1 REPLY 1
majedationE43S5
102 Views, 1 Reply
Can I add info other than NAME and VALUE to a component's symbol?
For example, I want to add the package (SOT23) or the component's name (BLM2305).
Some components have the same symbol and footprint, so instead of creating new components for each one, it's more convenient to use the same components in Fusion 360.
If yes, is there a table that shows what to write in the text box and which layer to place it on?
Thank you.
1 REPLY 1
Hi @majedationE43S5,
Along with the >NAME and >VALUE place holders you can create other text variables and then in the component editor you create the attributes that will represent that text variable. So let's say you want to show the Manufacturer's Part Number.  So in the symbol (and/or footprint) add text like >MPN. Then in the component editor create and Attribute called MPN and set it's value. When you use the component in a schematic the >MPN text will be replaced with the value of that attribute.
Let me know if you continue to run into problems.
Best Regards,
ā€‹Jorge Garcia
ā€‹Product Support Specialist for Fusion 360 and EAGLE
