Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Add components to schematic using the "ADD" window which was in the EAGLE
2 REPLIES 2
mail6LHAL
83 Views, 2 Replies
Does somobedy know how can I add components to a schematic using the old "ADD" component form which was in the EAGLE?
I hate the new design at the left side, the component symbols/footprints are hard to see, as I see the REPLACE form still exists, I want to open the same kind of form, but with the "ADD" title.
Thanks in advance.
2 REPLIES 2
jorge_garcia2
in reply to: mail6LHAL
Hello @mail6LHAL,
I hope you're doing well. If you could elaborate a little more on what you don't like about the place parts panel that would helps us improve it. For now it's still doesn't search on attributes which is why the old ADD dialog is still available.
If you want to use the old add dialog just type ADD in the CLI and press enter.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
mail6LHAL
in reply to: jorge_garcia2
Thanks, the "ADD" command opened the ADD window.
