Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
3D PBC from PCB won't correcly display
I have imported a .brb file of an antenna from NXP (I've attached the .brb) .
Here you can see that the the corners are displayed.
Howver when i click on View 3D PCB, it generates a design without showing the whole design (corners aren't showing.)
1. How do i correct this?
2. Does this mean there is also an error in my PBC deisgn, or just in the 3D model?
  • pbc
jorge_garcia
Hi @Anonymous ,
I hope you're doing well. I've contacted our developers on this so that they can look into it and get back to you.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Hello @jorge.garcia
I have also found another similar issue with makign a 3D PCB visualization:
with the file:  demoboardv2b.sch and demoboardv2b.brd (attached)
Visualizing the PBC top layer:
The bottom layer with just a connection:
However the 3D PCB design has the antenna coil even on the bottom layer, making a short with the connection:
jorge_garcia
Hi @Anonymous ,
Thanks for sharing this file. Our developers are investigating the issue and they thank you for sharing the files.
Best Regards,
Jorge Garcia
panpan_fan
Hi @Anonymous
I hope your are doing well! This issue should have been fixed in Fusion 360 V2.0.13516+.
Please have a try to see if works for you.
Panpan Fan
