Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
3d model into 3d pcb is it posible
3 REPLIES 3
fprico
229 Views, 3 Replies
Hi, I have done a 3d model of a led stripe, I need to output into  Pcb or gerber file. Can anyone explain me, is there is an easy way, or guide me to convert into pcb for export to gerber or pcb.doc.
here is the link to the model.
https://a360.co/3ijaSGH
Thanks.
3 REPLIES 3
edwin.robledo
in reply to: fprico
Hi fprico,
Thank you for participating in the Fusion 360 electronics forum.  It is not possible to generate Gerber files from an image in the Design Workspace. Gerber files can only be generated from the PCB Layout editor.
With the sketch tool active in the design workspace project the surface of your 3D model you wish to use in the PCB layout.
After finishing the projection sketch profile, select the CREATE PCB from create menu, and select the projected profiles. You will be transferred to the 3DPCB.  Push this image to the PCB layout.
Once it the PCB layout, you will notice the PCB outline you used in the 3D image you created. Use the ADD command to find the parts you need for this design.  After placing the parts and drawing necessary connections, then you will be able to generate your Gerber files using the CAM export.
Please keep us informed of your progress.
Best Regards,
Ed
Edwin Robledo
Tech Marketing Manager
fprico
in reply to: edwin.robledo
Thanks, this is what I have for now
https://a360.co/2VCHgKv
how do I create the contacts circuits of the pcb like in the image (attached)?, where could I find the 3w led componenent?
edwin.robledo
in reply to: fprico
Hi fprico,
Thank you for contacting Autodesk. We have a series of videos that will detail how to use Fusion 360 for your electronic design. Please follow this link to learn more about the electronic design capabilities of Fusion 360.
Best Regards,
Ed
Edwin Robledo
