Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
3D board genereted with problems
5 REPLIES 5
Kristey
141 Views, 5 Replies
After last update I have this error all the time:
I'm updating the 3D of a board, without changing components just updating the position, wiring and vias.
It's impossible to have a redundant dependency in this case, as well as the errors in the 3D components that sometimes appear, had previously worked.
If I remove the link with the 3D board, and create another 3D board, works again.
How can I solve this problem?
5 REPLIES 5
jorge_garcia2
in reply to: Kristey
Hi @Kristey ,
I hope you're doing well. This is a known problem and the fix for it will be out shortly.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kristey
I will wait to dthis update because is it very harmfull on concept workflow.
jorge_garcia2
Hi @Kristey ,
I hope you're doing well. The update has been released, so this you should be resolved. You might have to unlink the 3D PCB and re-link it but after that it should be OK.
Best Regards,
Jorge Garcia
Kristey
in reply to: jorge_garcia2
Do you have idea when the next release with this correction will be released?
Thank you!
jorge_garcia2
Hi @Kristey ,
I hope you're doing well. That correction has already been released.
Best Regards,
Jorge Garcia
