Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
2D PCB outline messed up after pushing 3D PCB to 2D PCB
1 REPLY 1
xpuipc
96 Views, 1 Reply
happy new year for everyone here....
Sadly i have the above very annoying issue again which prevents me to give my PCB to my supplier:
 3D PCB => this is the intended outline
=> 2D PCB => this is the messed up outline
Did nothing else than
1. creating an outline according the discription to create a derived outline from case
2. Pushed from 3D to 2D
3. Result in 2D you can see above.
I am on Windows, localisation is Germany if this is important.
Has nothing to do with the shift of the components (as you can also see on the picture), this seems to be another issue after syncing the kontext (whatever this does)...
Thank you
Torsten
1 REPLY 1
Hi @xpuipc ,
Happy New Year to you too.
Sorry to hear that you're having trouble.
Could you please try to create the PCB via below method, but not using the derive one instead?
If still have problem with the new method, could you please attach the f3z file with your sketch file which used to covert into 3D PCB here? Then we could have a try with your sketch file. Thanks a lot!
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
