Wrong generation of 3D model of a PCB
kimKV67A
kimKV67A
Wrong generation of 3D model of a PCB.
- The placement of components not match!
- Wrong drawing of canvases!
  • 3d
HelenChen-AutodeskQA
Hi @kimKV67A ,
Sorry to hear that you're having trouble.
Could you please share more information about the issue? Screenshots and videos could help us to understand your problem.
By the way, if your library has been updated with new version, you need to go to schematic or 2D PCB editor > Library tab > Libraries > click Update design found all libraries used in design.
Then the previous added part from the old library will be updated, and view in 3D PCB will get the latest 3D model and footprint. Otherwise it will still use the old version of library.
Not sure whether it's your case, just share with you to be aware of it.
Looking forward to hearing from you.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
kimKV67A
I have all ready update lib!
Sorry, but there is a lot about going form footprint to 3D, both in generating 3D in lib and in design.
* it some time not update tracks, pad.
* Some time with out I have make change in the footprint it not generate tracks and pads(copper)
* Some time some pads are missing
* It not update text, drawing around components, some components outline is still on the 3D model even that I have deleted this component form long time.
THE BIG PROBLEM IS THAT IT IS RANDOM!
Hi @kimKV67A ,
So sorry for my late reply.
Do you mind export your Fusion Electronics design to me to have a double check? I will private message you with my email address. Thank you.
Helen
Helen Chen
