wire width and clearance
7912661
7912661
Hello?
After update.
Errors continue to occur in wire width and clearance.
I don't know what the problem is.
help.
M1 MAC Book Pro & Intel MAC Book Pro
Sonoma
jorge_garcia
Hi @7912661,
I hope you're doing well. The best place to check what the clearance errors are caused by is to look into the DRC and Netclasses. Whatever is causing the violation will show up there.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Thank you.
Thank you for your kind advice.
But I solved it another way. Following Autodesk's advice, I exported to Eagle and then re-imported, so the problem did not occur.
