Which library has Polyester Film capacitors in Fusion 360?
masharul92
Observer Observer
masharul92
Observer
Observer
I am looking for these capacitors (shown in the picture).
I checked the rcl library, sparkfun-capacitors library, capacitors library, but couldn't find these. I need the package with circuit symbol, PCB footprint and 3d model. Please help.
jorge_garcia
Hi @masharul92,
I hope you're doing well. The rcl library contains footprints compatible with this type of capacitor. You won't find the word Polyester though. From the PCB perspective the material of a capacitor is irrelevant only the footprint is important since that is what will actually be considered for the layout. In the schematic you can then add attributes to further classify the part as polyester, electrolytic, tantalum, etc. You won't find a polyester specific footprint.
This type of component typically has a 5mm ish spacing between the leads so any of the 050 footprints should work.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
masharul92
Observer
Observer
masharul92
Observer
Observer
Hi @jorge_garcia
Thank you very much for your quick response.
In the rcl library I cant find a similar package with a 3D model as well. Could you please suggest what I should do? I am new to fusion360.
Best
Masharul
jorge_garcia
Hello @masharul92,
I hope you're doing well. I would recommend using the package generator if the 3D model is critical, it will also generate the footprint for you.
Since your new to Fusion, I recommend checking out this series of videos on library part creation.
https://www.youtube.com/watch?v=xNIEXCimRSg
Best Regards,
Jorge Garcia
