VIAs why do I get square?
christopher2KLSVU
christopher2KLSVU
After placing via on my board I get square, like in the picture. Why do I get it? Does it mean any error?
It makes board more unclear.
mjenkins5720
When you open the bet router, about half way down, you get the option for the shape. See attached picture.
I hope this helps.
christopher2KLSVU
No I mean the white square around my via . I took round via and it is fine , but why do I get square around via, Kind of viewfinder?
christopher2KLSVU
@RichardHammerl
@yqliu
@HelenChen-AutodeskQA
What is the purpose of this viewfinder?
RichardHammerl
Hi @christopher2KLSVU
sorry for the delayed reply..
The rectanguar shape is a drill symbol. Each diameter in the board has its own symbol. This can be used for a print out in case you drilled the board manually. The drill symbols help in recognising different diameters.
If you switch off the layers Drills / Holes they will not be visible.
Richard Hammerl
