Version history for electronics designs
jmosesLDHJU
Observer Observer
jmosesLDHJU
Observer
Observer
Does the "version history" feature of Fusion 360 apply to electronics designs, or only to mechanical drawings?
yqliu
Yes, it applies to electronics designs too.
jmosesLDHJU
Observer
Observer
Can you show me where to find it please?
jmosesLDHJU
Observer
Observer
Oh, I found it.  Thanks!
yqliu
It's the same with mechanical docs:
jonrbloom
The multi-document nature of the Eagle design schema makes version management quite awkward. It is clunky (and error prone) to rewind to a previous coherent version set because you must unwind each individual document to the known good version, manually drop the links in the master document, and re-link to the new latest versions.
At some point, when the app is stable enough to consider non-essential UI cosmetic changes like this, it would be valuable to have a single-select drop-down in the master document to wind back all the documents in the set to a known consistent previous version-set.
I am also keeping my fingers crossed for a day when the individual document scheme is dropped, in favour of a more holistic DB schema that maintains all 3 design elements together as a single document and broken annotation warnings are a thing of the past. Pipe-dream?
jorge_garcia
Hi @jonrbloom ,
I hope you're doing well. Thank you for the feedback, I'll pass this along to our developers.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
