Using APPEND when creating components
squigleyZWHQC
squigleyZWHQC
When creating parts in Fusion360 Electronics there is the APPEND function which allows multiple pads to have the same definition. GND is a common example for an IC.  But when the completed symbol is brought into a schematic the resulting gate looks like this:
When troubleshooting this leaves something to be desired.  I know PIN1 and some other pin are connected together but I do not know which pin.  The same is true for PIN4.  I think EAGLE used to display all of the pins.
jorge_garcia
Hi @squigleyZWHQC ,
I hope you're doing well. EAGLE didn't show the other pads in the schematic, this is the same as what was available in EAGLE.
Currently you can use the Design Manager to explore what pads are associated with a given signal in the 2D PCB.
I'll put in an enhancement request for this.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
