Unlock a wire
Unlock a wire
jcsantilli
Unlock a wire
jcsantilli
I'm just starting with electronics and I have a wire that is locked and can't figure out how to unlock it and delete it. In the properties tab I see a greyed out check mark but can't uncheck it.
How do I do it?
panpan_fan
Hi @jcsantilli
I hope you are doing well!
It's weird. The Unlock should work when you uncheck it in the Priority.
Would do you mind to try the Unlock All command in the MODIFY tab to see if it can work.
If it still can't work, you can send me the file and I will check it for you. I will send my email to you in a private message.
Panpan Fan
