unexpectedly closed solder mask in 3d-model
dongli_zhang
dongli_zhang
I'm working on a 3d-model for my PCB with a library of my customized component. The Footprint consists of a customized polygon on top copper and the same pattern on tstop and some border lines on dimension (picture 1). An SMD pad is placed on top copper to form connection. I expect the polygon part to be open on solder mask and the tstop was displayed correctly in PCB board interface (picture 2). However, when I switched to 3d model, the solder mask was not properly opened. Only the part on top of the smd pad was opened (picture 3).
I assume this was because I copy-pasted my polygon from top copper to tstop to have the same pattern on both layers, since I got the error in picture 4 when I did this.
How can I deal with this?
Thank you and have a great day!
jorge_garcia
Hello @dongli_zhang ,
I hope you're doing well. So first off, your 2D file is correct and is the source of truth for the design. At this moment in time the 3D PCB can't render all features correctly and this comes up most often for arbitrary pad shapes like the one you are working on. One thing you can try to see if it gives you the right rendering is to go into the 3D PCB settings and make sure Stop Layer Geometry is checked. Let me know if you continue to run into problems.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
dongli_zhang
Hi Jorge,
thank you so much and you made my day! I turned on 'Stop Layer Geometry' in settings and now the solder mask is displayed correctly!
Best regards,
