Message 1 of 9
Undo command bugs: Can't hold Ctrl+Z, and Undo shifts view window sometimes
Fusion 2704.1.53
- Eagle v9.6.2: You could press and hold Ctrl+Z and Ctrl+Y to quickly undo or redo a bunch of stuff really quickly. Fusion: You need to either use the mouse and do some clicking (the Undo menu is limited to 30 items), or type undo list and click things there, or press Ctrl and then tap Z or Y one time for every undo/redo action.
- Sometimes when Undo and Redo are used, the view of the PCB shifts slightly. Even if I'm working in the schematic, with the PCB on another monitor, and I use undo/redo in the schematic, the PCB view will sometimes shift a bit.
edit: and Undo often is just very laggy, even for very minor undo actions, sometimes even locking up the entire program for several seconds while the cursor spins...
