Unable to Select Printer or Print File
mike6A8ZN
Message 1 of 1
mike6A8ZN
I recently started using Fusion360 electronics from having used Eagle for many years.  I need to print my PCB layout and drawings.  When I select the output button I was able to briefly select the HP printer on my network, but nothing would print.  Then all of a sudden I am no longer able to select my printer.  It seems my only option is to print to PDF and then print the PDF.
Printing to PDF then printing the PDF doesn't work for me.... especially when I know I should be able to print my schematic or PCB directly from Fusion360.  So what is up with this behavior?  I scanned other forum posts that suggests this is a known bug....if so, when will it be fixed?
Replies (0)
