We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
Unable to select a hole in a PCB
m4vrick99
m4vrick99
I have an issue on several projects, for all of them I could not select, edit or move the mounting holes I've made in the PCB.
I used the Hole function at the beginning of my projects several months ago, and today it seems they are permanent. I tried to select them with a box, bu clicking on the edge or around the center.
I can select the outside edge of my boards, the issue is only with the holes. In the selection filter Hole is enabled.
I found a way to select them through the design manager with a filter over hole object, but it could be more useful to select them like any other component in the workspace.
jorge_garcia
Hi @m4vrick99,
You've covered most of the usual subjects. The other thing I would say is to make sure you have your drills and holes layers active. If the selection filter has them enabled and these holes were not made inside a footprint then they should be selectable on the 2D PCB.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
m4vrick99
Thanks for your reply.
When selecting a hole through the design manager panel there is no layer associated to them. I really dont know what's happened.
I remember there is something about changing the number of layer in a previous new version, maybe it's related to this.
Anyway I have a workaround and I'll see how it works with the next new projects.
