Hi
@david.g.johnson,
I hope you're doing well. You'll have to make the adjustments to the schematic and board themselves. If for example, the error is that a certain component shows up on the schematic but not on the board. In that case the easiest solution is to delete the part from the schematic. As you make the changes keep running the ERC once everything has been corrected, the ERC will report that board and schematic are consistent.
From there you can keep moving forward.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
