ULP file causes Fusion to freeze
andreas_4VZ35
andreas_4VZ35
Hello, I just found out that my ULPs file length caused fusion to crash all the time, when trying to display the ULP window from schematic or board..
Maybe you could have a look at this issue and fix it in future version.
Thank you!
EDIT:
After some tests I found out it was not the file length.. It was a comment at the end of the file which was causing the crash! So it is not allowed to do something like this:
ULP code
// comment at the end
BTW, it crashes also in EAGLE 9
jorge_garcia
Hi @andreas_4VZ35,
I hope you're doing well. Would you be willing to share the ULP? I would like to put it together with the defect report, there could be something else in the ULP that causes the crash.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
andreas_4VZ35
Hi @jorge_garcia,
here is an ULP that already causes the freeze. Just a random comment, nothing else in it. After you copy it in your ULP directory, EAGLE/Fusion freezes when trying to show the ULPs inside this directory.
jorge_garcia
Hello @andreas_4VZ35,
Thank you for sharing the file, I can reproduce the problem with your file. I've made a defect report for it and the devs will check out the best way to fix it.
Best Regards,
Jorge Garcia
panpan_fan
Hi @andreas_4VZ35
I hope you are doing well!
Today we release Fusion V2.0.20754 and this issue should be fixed now.
Please have a try, thanks a lot!
Panpan Fan
