two issues
two issues
Message 1 of 9
two issues
When i updated the library all the 3d parts are not showing up in 3d PCB.
The PCB outline and screw holes are not updating from the 3d PCB.
Replies (8)
Message 2 of 9
ESCAPEKIT
This is pretty common, we all are having this kind of problems. Fusion Electronics should NOT have been released because it has countless bugs. Try and go back to Eagle if you can.
https://forums.autodesk.com/t5/fusion-360-electronics/3d-packages-are-being-left-out-randomly/td-p/9...
Message 3 of 9
want to, but they remove the eagle + fusion link so  i have to forcefuly use that buggy fusion electronics,
and it's a common way to find bugs by releasing early.
Message 4 of 9
jorge_garcia
Hi Shaberadda,
The eagle+fusion link has not been removed. We released 9.6.0 which fixes the broken workflow so you should be able to proceed normally now.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 5 of 9
i am getting this error. i am using 9.6
Message 6 of 9
@jorge_garcia  anything in the this issue?
Message 7 of 9
jorge_garcia
Hi @Anonymous,
In this case, you have to link the board to it's own file. It looks like whatever file you originally linked it to contains more than just a PCB. In this case you either remove those types of features in the Fusion File or in EAGLE break the link and push to a new design in Fusion360.
Best Regards,
Jorge Garcia
Message 8 of 9
@jorge_garcia
it was same PCB just fusion and eagle got updated. Okey i will try to break the lick and try again.
and any fix for the in 3d pcb no components are not showing up?
Message 9 of 9
jorge_garcia
Hi @Anonymous,
The fix for no components on the 3D PCB is still being worked on.
Best Regards,
Jorge Garcia
