TPlace components drifting off as I rotate
andrewbarry3000
andrewbarry3000
Hi all look at both pics below. I rotate 180 degrees and the + and- drifts off a bit. Whats causing this? The circle diamteter does not move at all-Andrew
jorge_garcia
Hi @andrewbarry3000,
The reason for this is that in the original library the negative and plus sign don't perfectly line up with the origin of the part. Whenever the part was made the creator of it probably eyeballed their location.
It won't create any problems for manufacturing if that is what worries you. You can always copy the part to your own library and change it there.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
