Too many crashes when working with 2 screens
mario.brizida
mario.brizida
I use 2 screens to work with Fusion Electronics.
When, on the secondary screen I try to make something that involves logins, Fusion crashes.
When I pass for instance pcb folder to work on secondary screen, bottom quick function bar disappears.
Please don't forget Fusion Electronics when doing an update.
Thank you.
MB
jorge_garcia
Hey @mario.brizida,
I hope you're doing well. I've reported this and it's being investigated.  Could you provide more information about your computer setup? Any and all info will help us figure this out.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
qubecl
Hi everyone,
I've found the same problem with the disappearing function bar on the bottom of the screen when using schematic and PCB in two separate windows. It seems that only the bar on the PBC tab disappears when using it in a separate window, but not when separating the schematic tab from the others.
Best regards,
Lorenzo
mario.brizida
Hi Jorge,
I think that the problem is not connected to my computer's configuration.
User qubecl  (Lorenzo) also reported the same problem on working with 2 screens:
Hi everyone,
Best regards,
Lorenzo
Anyway, I use a pc with Windows 10. Do you need any specific configuration more?
Please don't forget also the second problem:
When I put for instance pcb tab on second monitor and in that monitor I try to go to autodesk account for instance, Fusion crashes and I loose all unsaved work.
Thanks for your attention,
MB
