Today expieriences, bad as always
christopher2KLSVU
christopher2KLSVU
-Polygons from Bottom Layer are not rendered, tracks ok - yesterday all was fine.
-Packages which were yesterday fine today are not generating 3D boxes, view or whatever, even after libraries update! - I did not change anything since yesterday within libs - just this stupid fetching library update. I did not touch these own libs which report 3D error.
-Every time I re-render 3D view my next own part is reporting missing 3D package and view. You have no order at all in keeping libraries references correct and library management system!! who the f k is working on it two students as summer interns ? !
Why this crap software is everyday worse???? Or am I get stupid everyday more and more from using this crap software????
Try to load old project, from yesterday this crap software will then always ask till end of your life if you would like to load the newest sch or PCB, which I do not need when trying to get the one from yesterday.
jorge_garcia
Hi @christopher2KLSVU,
Without images or a file it's hard to know exactly what could have happened. I saw in another thread you posted a screencast that would be helpful here.
One thing that may help in sorting this out is to look at the properties of your components since we can see the library information and match it to the current version of your library.
The other thing that is unusual to me is that you are opening older versions of your design, typically you would work on the latest version and save continuing to progress on this design. Could you elaborate on your use case?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
christopher2KLSVU
@jorge_garcia
If the software would work as it should I would not open previous version of my project. This is not source of a problem.
Your, Autodesk unfinished beta-alpha software have permanent problem with keeping references to library or within library. I am not an expert here, but this must be the root of everything. How could it be that one day everything works fine and another no? Without any user input, just close app at the end of the day.
I  only created own 3D packages for three  or 4 connectors  and few parts. Typical way, snapeda or from manufactures page like Ti and saved it in my Admin folder libs. This is normal user scenario, NO ANY BLACK MAGIC. One day everything works fine, the next day it looses 3D package for part A, after next rendering to part B( and part A is already fine self recovered lol), after next rendering to part C whereas A and B are already fine and so on and so on , always something.
Autodesk can not handle or manage to keep libraries stable. There are always some other missing references to script or ulp or whatever when user want to just use it. After App restart is fine, no complaining about missing script files..
I did not mention that it is always crashing when dealing with self created parts.
christopher2KLSVU
When talking about polygons problem, I even tried to add completely new polygons in different pcb place, just to test. It did not render as well.
