Tenting Vias
Tenting Vias
jens.bennerEGSLG
Tenting Vias
jens.bennerEGSLG
Hello all,
is it possible to tent vias only from on side? E.g. tenting via on top layer under a BGA Component and leave ist untented on the bottom side to use the via also as test point?
Kind regards
Jens
jorge_garcia
Hello @jens.bennerEGSLG ,
I hope you're doing well. So this is possible but it will be a bit manual. Here's the procedure
1) Fully tent the via
2) On the side you want exposed draw a filled in circle on the appropiate stopmask layer.
You are basically drawing in the openings you want manually.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
jens.bennerEGSLG
Hello Jorge,
ok. Thank you very much!
Best regards
Jens
