Sync delete old traces
laurent_dardinier
laurent_dardinier
I have been using Fusion 360 Electronic for 3 weeks now and get some troubles about syncronization (that is never automatic). When I modify my schematic and activate sync, the old traces concerned by the modification and some others are deleted!!
For example, I added pull-up on my I2C lines and after sync all IC lines have gone away. Same thing for ground plane. I add/modify a GND connection and all my GND plane disappeared! It is very very time expansive and deconcerting.
How to do to workarroud this problem?
Thank you.
CGBenner
@laurent_dardinier
Hello, and welcome!  I'm sorry you are having problems.  Maybe @jorge_garcia can help?
Chris Benner
Industry Community Manager – Design & Manufacturing
jorge_garcia
Hi @laurent_dardinier,
With Fusion it's important that the schematic and the board are always open together. That way they will track automatically. The synchronizer should only be used if a consistency has been broken.  There is no need to regularly use the synchronizer.
Could you elaborate on your workflow?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
laurent_dardinier
Hi, @jorge_garcia
I know that , I tried. The way I found to get it work is to export schematic and layout to eagle format and then import files in order to create a project. That way it seems to work properly.
Laurent
